Hi.
Is there a way to add resolution to only part of a model inside Zbrush? Right now I am doing that inside Sculptris and import it back into Zbrush.
Hi.
Yes:
Can I do that only at the lowest subdivision level? Why?
You have to do it at the lowest level because otherwise you would lose the lowest level (each level subdivides each existing polygon into four). The extra polygons will be propagated to the higher levels.
Thanks
