Hello! I’d like to change brushes behavior in zbrush. By default it’s like this: you put down the pen, and start moving it around, the geometry rises on a certain level, depending on your z-intensity, and then stops rising, until you put your pen up and then down again. And what I want, is that it would continuously rise and rise while I move the brush, like in 3DS Max with Push/Pull tool. Is it possible to do this?
In the brush menu (top of screen) there is a setting called Samples…inside that is a button called “build up”. Turn it on!
That’s it! Thank you very much!
