Would be nice if multi mesh insert brush has a kind of scatter mode. So it could scatter various things randomly with a scale and rotation variations.
The Spotlight would be so much more useful if it allow to use two different images for depth and color simultaneously, a kind of complete material while painting/projecting. Or at least an ability to paint the depth from one image and color from another with ability to lock those two images to the same place on the screen and to each other. A good example is Material painting in 3d coat.
Would be so much easier if It we could use Alt button the same manner on layers as it is by default , to alternate brush behavior and color. Not as an eraser. Pixologic, please, appoint another button or just a specific brush for erasing. That alt based erasing eliminate very unique and helpful brush feature on layers and makes layers quite useless for texture painting.
One more feature request. Pixologic, please add object(tool) ID color pass. I know I can do it by hand but would be nicer to have it done automatic as a render pass.
There is a script for ID colour pass.
http://www.zbrushcentral.com/showthread.php?167639-My-Zbrush-Plugin!
- Random Color: this script was requested by someone on the fourms. It will assign a random color to each of your subtools. This is useful when rendering a flat color pass so you can easily select your subtools when compositing.
Thank you
looks like no more working with r5.
