Hi! I’ve been using Zb for a good while now, and there are certain elements which bother me.
- Saving. In EVERY other app I’ve ever used Ctrl + S saves the scene without any kind if dialogue box. But not Zbrush. Oh no. Zbrush needs to open a dialogue box. It’s not a big deal if you only save once a day, but I save all the time, and this is taking up time and it interupts my workflow.
Is there a way to make Ctrl S simply save to the currently open project without interrupting me?
- When exporting models from Zbrush I notice that the position, scale and rotation may be off. This seems to happen at random. Sometimes the scale is off, sometimes the rotation and sometimes the position. Im currenly working on a project now where the models get rotated 180 degrees on the y axis. The UV maps are also flipped.
Any suggestions here?
- I have problems with seems and normal maps. Whenever I make a normal map, the seems are clearly visible in the render. I use modo, for the record.
