4r8 Render Render Snapshot object fail
Hello, I have a problem rendering multiple views of my object, I put my object, click on snap shot, move the object put on the position, click on snap shot again, and finally when I have the three views for example, only render the last view, I try to turn off and turn on different things but doesn’t work, any tip?? help please, on differents tutorials looks pretty easy :frowning:
Thanks in advance
If you are using BPR then that only works with a model in Edit mode. The snapshots are pixols and won’t render.
ok, that’s made sense, so only works clicking on render/best render, but for the best render possible, I need to make a BRP render with separate layers… thanks for answer so fast :slight_smile:
