4R4 Virtual Memory/Cache File
I read that in Zbrush 4R4 “The location of the virtual memory/cache files can now be changed”
Can you explain please how to?
I’m running windows 7 64bit, where i can find this setting in order to move virtual memory/cache files to another hard disk than my C disk where ZBrush is installed?
Thank a lot!
Dear Lannabulls,
I had the same problem.
I found a configuration file in C:\Users\Public\Documents\ZBrushData.
I change the path specified in the document and now mem file appear in a new position.
Bye,
Flavio
You can also use Windows 7 symlinks or junction links features to direct to another folder depending on if you use the same drive or another drive. That is what I use myself here.
