4r4 - Multi Map sometimes doesn't work
Useing R4. Sometimes, Mult Map exporter won’t create maps for a subtool. It goes through the process and everything, but when I go to the folder where I saved it to, there is nothing there. Meanwhile, all my other subtools bake out fine. This is my second time using Multi Map and the second time this has happened. Trying to bake out Normal, Ao and Cavity.
Any ideas, suggestions.
Thanks anyone.
If you can let me see a model that has this problem I will take a look. I’ll PM you with my email address.
