4.2 noise transparency doc error
the mini tut on page 54 of the 4.2 docs has an error. the line “below the curve in the noise window, move the focal shift slider to a negative number” - should refer to the the offset slider not the focal shift. if the offset is used everything works great.
hope this saves some people some pulled head hair.
Thanks I was just about to post an issue about this, but you’ve solved it for me…actually haven’t actually tried your method yet. Yep works thanks!
Definitely saved the little bit of hair I have left on my head :smiley:
Thanks Magbhitu!
