Hello, I’m new to zbrush and I got some problems while trying to unwrap my model-
first- my model is simple- a cake and a plate attached to it- i do not want the plate (it’s an imported model) so i’ve deleted the plate but when ever i press unwrap the plate appears like it was never deleted. why is that ? and can i avoid it?
second- when i tried to apply the protect color in order to unwrap it in the direction that i want it does not appear to work ( i can’t see my imported texture as well , only when i press unwrap and it still has the plate and the texture is not unwrap but placed uncorrectly on the model ) i try to use the paint poly from texture but it’s not avalible to use (to press it atleast)
what can i do?
would appreciate any advice on the matter. thank you.
