Hi Lemo ,
Thanks for all the great advice !
I am more experienced modeling with polys in Maya . I was a bit confused with box modeling in Zbrush because there is no select Face or Edge tool and no extrude function .
I was reading on another thread that you can do something similar to the traditional poly modeling using Edge Loop .
It’s ok about the model though . It was mainly a test head for me to see if you can make a head out of a 3D Sphere in Zbrush . Now I know it’s not a good idea . The great thing about this program is that it takes such a short time to get things done that doing another head from scratch is really not a problem
Also look at box modeling techniques. Most of the superior heads have started with a hand full of polygons and already looked remarkably like the end result. Try to get the character into your work before you apply to much poly’s. Or… you end up with another offering to the god’s of displacement
I agree 100% . It’s a bad habit I seem to have picked up since starting Zbrush .
I checked out the thread on making the topology on a cube good to model on . But in your opinion is it better to make heads with Zspheres or Cubes ?
Thanks for your time and patience .
Best Wishes ,
Kevin
