3D Retopology Service
Offering Retopology services for Organic and Mechanical models.
This is fairly straight forward, Retopology is a tedious and time consuming task; I’d like to do it for you.
Organic(character) assets are retopologized for Animation, Low poly or a moderate poly count.
Low Poly being the bare minimum to gain the shape of the character, Moderate is the level of polygons necessary to capture every important feature and not leave anything out.
Quads only or with triangles depending on your intended use of your models (Usually this means if you intend to subdivide them or not)
Mechanical models are retopologized with efficiency in mind, How tight the poly restriction is dictated by you and whether parts will be animated and in what way.
Prices are flat rates, $40 for Low Poly character assets, $80 for moderate character assets. Mechanical models are judged individually (But swing on the lower end depending on the number of parts).
If you’re interested you can place an order at: 3dretop.com/order
Include a download link to your model with instructions of your desired result, Payment is handled via paypal.
Retopology is a tedious task that’s necessary in the 3D world, Either you’re a sculptor that wants an animation ready low poly model from your work.
A commissioner who has models with inefficient topology you’d like fixed or a developer looking to save time by having someone else do this tedious task.
3dretop.com and i’ll sort it out for you, Ty.
Any feedback on this service email me at: [email protected]
My goal is to build a turn key solution for new sculptors especially to lessen the load of getting into 3D, allowing them to bring their experiments etc into other software without worrying about retop etc.
Offering rigging services for character and mechanical model assets, Email us at: [email protected]
With the title Rigging if you need your assets prepared for animation.
