I’m working with some medical skull models from mimics. I first dynamesh them in zbrush, then decimate, then export either with the stl plugin, or export to obj. I keep my original file from mimics untouched as a reference in Rhino, and when I import the zbrush model it has always been centered and scaled down - I then have to manually try to match the scale of my original model in rhino.
Is there a way in zbrush to make sure that the model isn’t transformed or scaled? Also I can’t seem to find a reference anywhere on what units zbrush is using for measurement. I’ve been using mm in rhino so the scale issue’s could just be because of that.
thanks
