3d printing exporter
hi
Does anyone know if its possible to find out the size you have specified for the model in the exported file? Specifically in the case its an *.STL file. As in the actual file i sent to the printers.
cheers
  1. Select the Polymesh3D Star.
  2. In the 3D Print Exporter menu, press the STL Import button and select your file.
  3. At the top of the 3D Print Exporter menu, press Update Size Ratios. The Size of the imported model will then be displayed.
