Any help here would be appreciated.
I’ve been saving STL files for printing but suddenly the files aren’t showing up anywhere.
But it says they were exported successfully.
I name them, I’ve searched my computer for the names I’ve given them in the dialog box when exporting, I’ve searched the subtool name as well to see if they landed somewhere obscure on my computer with the subtool name.
No joy.
I even made special folders to put them in when filling in the export dialog box.
Restarted the program, no joy.
Same with the computer.
Tried other files. No luck.
Tried a file I recently successfully exported as a STL before it stopped working. No luck again.
Always the same. Says it worked, but they don’t exist anywhere (unless it totally re-names them and randomly puts them somewhere that I don’t know about!)
It was saving the files just fine and then doesn’t.
Anyone know why or better, how to fix it?
My iMac is running OSX 10.6.8
ZBrush 4R6
I’ve had no luck for half the morning trying to figure it out!
Thanks!
You could try to update to P2.
It says ZBrush 4R6 P2 etc in the top left, but I tried the zplugin updater which said no updates found, so I already have P2
I tried again, just to check, still no joy exporting stl files (although it still says it did)!
Having the same issue. Hopefully someone has a solution.
