3d Layers - Rec Shortcut
Is there a way to create a shortcut to activate/deactivate rec mode? Driving me nuts to press that manually every time I switch a layer.
Thanks!
You can do it with zscripting. Here’s a little plugin.
Unzip and put the ToggleRecord.zsc in the ZBrush 4R7\ZStartup\ZPlugs64 folder. Restart ZBrush and you will have a new Toggle Record sub-palette in the Zplugin palette.
Assign a hotkey to the Toggle Record button. The switch is for whether you want the layer left on or off when recording is turned off.
Fantastic. I’ll try this now. Thank you marcus!
