3D Connexion Space Mouse extra settings?
Hi, I’m new to ZBrush, I have a regular 3D Spacemouse which I use with things like Blender and Unity. I’m pleased that ZBrush now supports this device, however, I can only seem to locate settings to activate that functionality. Unfortunately, for some reason, when I use the Spacemouse, all settings seem to be inverted from the way in which I usually use it. The only workaround so far has to be to turn the mouse 180 degrees and use if facing the other way. Are there any settings hidden somewhere so that the mouse can be tweaked and fine tuned for ZBrush use (within ZBrush) ? It would make life easier moving forward, if the mouse just does what it does in my other 3D creative programs. Thanks
Hello @Matthias_Plunkett ,
Advanced settings for customizing the behavior of the device can be found in the device’s configuration utility that installs with the drivers. The available options may vary with the model.
Please note that these devices are supported by 3D Connexion. If you believe you have an issue with the functioning of ZBrush on your system, please contact Pixologic Support. Technical support for ZBrush is not provided over the community Usage Questions forums.
Thank you!
