32 or 64 bit????????? help please.
Im looking to get a new pc and before I did wanted to make sure weather or not I would need a new version of zbrush if I went to 64 bit.
Here is potentially some really dumb questions:
Are there separate 32 bit and 64 bit versions of Zbrush 3.1?? Or is Zbrush 3.1 64 bit compatable? Would I be able to use more RAM for more polys with a 64 bit, or does Zbrush have a limit regardless if your using a 64 bit system. Im sure this has been asked before but the search engine filtered out 32 and 64.
THANKS A TON!!
okay I just found some info on the wiki, sorry.
