Hi guys, has anyone else come accross this problem. I’m trying to render a scene in maya 2008. It sources a 32bit displacement map. Our farm used to have maya 8.5, and the scene rendered fine, we upgraded a couple of days ago, and since then it no longer uses the displacement map. On the formus here they say "appearently Autodesk put in a new “feature” in the preferences that needs to be switched ON for Maya 2008 to properly render zbrush exported 32bit displacement maps!
Window > Settings/Preferences > Preferences > Settings > Rendering > Mentalray Preferences > Use Maya-style alpha detection on file textures."
Ok, I did this on my local machine and the scene renders fine, I also set it on all the machines on the farm, but these are preferences within maya, which obviously are not taken into account when rendering maya batch, so it still renders without displacement. Has anyone found a solution for this, and does the fault lie on Autodesk, or Royal Render’ side.
