Sorry, don’t know where to ask…ZBrush4 acting strange (hasn’t done this before).
- Square & Center options not available for strokes
Thanks!
Thanks!
Resolved #2 & #3…using ZB on a different machine (Win7)…still
can’t use the Square & Center options on a stroke yet…must be my
noobness.
Will keep at it…thanks.
Ok, I just played around with it and center and square are only available
when you are using masking or visibility with a circular or rectangular brush.
However if you dock the stroke panel you will see a rectangular stroke with those options for the other brushes, but it doesn’t seem to do anything.
If those option don’t show up in masking or visibility then you do have an issue.
Matuka,
Thanks! Just realized that I had to hold down the control button not only
to use the brush but also to activate the Square & Center options.
ps- small world…I’m in Escondido.
You’re welcome. I’m actually in el paso right now but will be back in sd tomorrow. I’m in university heights. If your not doing anything on labor day come on out to qualcom statium for a car show I help run.
