3.5r3 - Tab Key to Hide UI
Is there a way to get the right panel to hide when I hit the Tab key? It seems to be the only one that doesn’t do so.
I looked around for you but found nothing at first. Everything I tried left that window open on the right.
Then I started thinking and this is what I came up with (workaround, same functionality).
If you create a hotkey and bind it to the Tab key, you can hotkey the “Load Next User Interface Layout” and cycle through your UI’s using tab.
If you create a UI that has everything minimized, and one that is “normal” as your two UI’s to cycle through, and then bind Load Next User Interface Layout to Tab, (by pressing control and clicking the button up top right), you get the same effect and this does work to minimize all the trays and even the shelves if you set it up that way. Simply press tab again to cycle through to the UI where everything is open.
Not elegant but pretty easy and it does the same thing.
I’ll give it a shot. Thanks for the creative workaround!
