3.5 Questions
What is suppose to be in the Light Box. For example under all the folders you click and there is nothing there is most of them.
How to permanently load help files and quick links to ZB central in to ZB UI
How do you dock a tool pallet on the bottom. Drag & drop not working.
Is there a way to set up center mouse wheel for the scale (Zoom) function? OR a way to resign the way the zoom scale works? “Ive never liked Alt/Release to zoom. I would like to set up
Navigation in Zbrush is horrendous and I can’t believe the mouse wheel has never been addressed. A mouse wheel zoom would be such a welcomed addtition. Or a middle button (mouse wheel) pan. It sure would make life easier.
nevermind , havent read carefully.
is there a way to use them? How do you use decimation in 3.5?
One question to the Support: It seems I can’t access the files from my D: partition from Lighbox, just C:. Is it really supposed to work this way?
Right-Click navigation doesn’t work for me when Move, Scale, or Rotate translation mode is active…it just functions like the left-click for Transpose.
