Hi Aurick, thanks for the speedy response! Here’s a copy of one of the documents I’ve created that are giving me trouble. This is very much an early work in progress, but I appreciate the help towards a solution for when it really means something… in another week if all goes well. Thanks in advance.
Test File LINK
Previous Conversation:
3.2 Render "Best"Crash
I’ve got a strange issue with my Zbrush 3.2 (mac) crashing on the very last 1% of any sized render set to “best” quality. It doesn’t seem to matter how large or small the image is… it just doesn’t like the “best” setting… or rather completing the render. Has anyone else had this issue? A search didn’t show to much. I don’t remember having this problem on any other version of Zbrush that I’ve used in the past.
I have less then probably 12 matcaps I’ve loaded in addition to those that ship with 3.2
Tried even with a clean install and still had the same problem.
It makes my renders look so much cooler, so I have to figure something out.
I can render this all out in Maya or Max, but the point was to try to get the exact results I was looking for right out of Zbrush.
I’ve dropped the tool to the canvas, saved as a document, fired up a fresh session, loaded the doc only and rendered getting the same crash at the very end of the render… as if it’s having trouble writing the final file to something possibly?
Appreciate any advice or troubleshooting that can be provided. I can provide files to test with on your version if requested. Thanks.
__________________
