The ZTL’s from ZBrush 3 on PC (Bootcamp) completely breaking ZB 3.12 Mac…
Anyone else found this, anyone found a fix???
It seems to be related to resizing the document window, if I leave it as default the ZTL’s load fine, if I resize the window then load a ZTL it goes wonky, not ideal on a 30" monitor…
But at least I can now load my old tools!!!
mine worked. I put them on a WD drive in bootcamp and restarted osx and pulled them off.
I had a problem bringing in a ztl from the Mac 2.03 version of ZBrush. It was a dinosaur that came in as a weird looking box.
To fix, I just exported the ztl as an obj from the 2.03 version and it came in fine in 3.12. Tonight I will test some ztls from my windows 3.1 bootcamp version.
Thanks guys, my issue seems to be stemming from changing the document window size, anything other than default gives me a black band at the bottom!!!
This happens even with “Pro” on or off
I wait over a year & I’ve broken it already!!!
I’m loading tools from ZB2 (PC) & ZB3.1 (PC) with no issues other than the work area is really tiny…
I hear that, I crashed it 4 times doing a render last night.
Instructions have been provided for reporting errors with 3.12. See here: http://www.zbrushcentral.com/zbc/announcement.php?f=8
