Hello, the 3.1 upgrade went well, I got the help docs installed just fine.
One question, when I build my new computer, how do I make a backup of it and get it working?
thanks,
Seth
thanks,
Seth
There really isn’t a way to back it up like that. When you build the new computer, simply download the trial version and install that. It’s the full 3.1, and you can activate it with your serial number.
If you have any custom content installed, you can make a backup of your ZStartup folder. Then after installing the trial, simply replace the new ZStartup folder with the backup. Also, if you’ve customized your interface you’ll want to backup your UICustom.cfg file. That’s it!
If you’re not going to be using the old computer anymore, be sure to launch ZBrush on it and press Zplugin>License>Deactivate License to return that activation to the licensing server!
Thank you so much aurick, this is just what I was needing :).
