Dear community - I am travelling / away from my studio where I use a 2nd monitor on my macbook…
When I open ZBrush it disappears off screen to the monitor that is not plugged in!!!
Apple have been unable to help with at least 5 fixes that did not work - I submitted a ticket with pixelogic and was told the following:
1: Hi Bradley,
What you will need to do is delete the startup window size file. Unfortunately I do not have access to a Mac at the moment so I cannot tell you the exact filename, however it is named in a way that you will recognize it. You will find it located in either ZBrushData\ZStartup or ZBrush 4R6 OSX/ZStartup. This will reset where ZBrush is defaulting to.
This did not work, I replied and got answer 2:
Hi Bradley,
It’s a text file, I believe. And it’s not in ZData. It would be in one of the subfolders of Users/Shared/ZBrushData or in ZBrushOSX 4R6/ZStartup
This also did not work and I have not yet had a further reply - Im up against a deadline on a major project, working overseas without my installation file which is backed up at home…
Can anyone help!?!?!?!
Also ZBrush is visable as open on a floating window when looking in apples ‘mission control’ as previously mentioned it disappears off screen when selected
AArrggh
