2 Very Stupid Quizs
1:How can i set a different Materials into a model…
eg. a snail’s skin and its shell…
2:How can i setup the new UV group in Zbrush? Do i must set the UV group in 3rd part software before i import the model into Zbrush?
Thank you master!
  1. Turn on colorize mesh (it’s in the “Polypaint” Submenu of the Tool Menu in ZB 3.12) You can then paint mateial with your brush assuming your brush is in M or MRGB mode. (By default near the top of the screen.)
  2. Polygroups can be created inside ZB3 (Polygroups submenu) but I think to do custom UV groups, you need to export your level 1, UV it in something else, and reimport your level 1.
HTH,
-K
thank you very much~
