2.5d to 3d is it possible and how to do it.
ok all just signed up and im having a hard time with this…when your in 2.5d mode in zbrush doing whatever to a face or whichever thing you may be working on…and using the brushes or anything…is it possible to make that 2.5d image to a 3d one so i may do alot more to it? i was playing with a face i made in facegen and loaded the obj to zbrush…that was fine…after i did some stuff to the face i cant figure out how to make it a 3d model again to turn it and all the other things i want to…plkease help.
thanks all…
2.5 to 3d can’t be done…at least, not in the way you want.
you need to make the object in Zbrush 3d…or be in “edit” mode.
check out some of the basics on Zbrush here…
http://www.pixologic.com/zclassroom/
