2.5d brushes...is there a way to modfiy
2.5d brushes…is there a way to modfiy to have them behave differently, for example, to mimic other 3d brushes, like an Hpolish 2.5d brush, a smooth brush, a Dam_standard brush ???
How much have you played with the ones available?
Not really but why would you want to? All you need to do is work in 3D and then drop your model to the canvas for it to become 2.5D. Also, with this plugin you can have the best of both worlds:
http://www.zbrushcentral.com/showthread.php?172391-Useful-small-ZScripts-and-Macros-for-ZBrush-4R6&p=979836&viewfull=1#post979836
reason being, I am dropping tools to the canvas, but do not want them to simply intersect with each other. I am blending and filleting them out into each other for smooth transitions.
the brushes available are rather limited, basically i am just using the simplebrush with an alpha to sculpt the pixols and smudging them to blend more, but would be nice to have 2.5 brushes that function like the 3d brushes mentioned.
Smudge brush, with different alphas and stroke settings and don’t forget Zadd and Zsub will do quite a bit.
yup…i’ve played around with all of those, not quite the same effect…was more curious if its even possible to create different 2.5d brushes?
