2.5 d move tool?
Is there a way in 2.5d mode to use a tool like the move tool and smooth tool in 3d? I think it would be very handy to have. I just want to move a small area or smooth it out, but can’t do it with the 2.5d. any ideas?
Hey there JT ;),
one thing you could do is using the Hook Brush with a focal shift of around -30. It behaves pretty much like the move tool. Also don’t forget that for the last stroke you did you can go into Move (+scale and rotate) mode in order to place your pixols.
For smoothing you could use the smudge Brush with a very low intensity. Something like 6 works ok for me.
Hope that helps a bit!
Thanks, I’ll try it out. You always seem to find a way. :slight_smile:
