16 bit alpha import with error or blank - Resolved
guys,
since the introduction of ZB 4 i can neither load my 16 bit tiff greyscale alphas anymore (which worked fine until zb4 and do now pop as error), nor will 16 bit greyscale PSD work (CS4), which will import but only blank. From web research it appears to be a common problem: only small size (512*512) alphas import correctly. Larger ones break (think: displacement map). Thats a nasty one. Can you please confirm this is on the fix list?
thank you
Try setting Preferences>Performance>PreLoad File Size to its max value. See if that resolves the issue.
wow, yes it does! Many thanks for the help! Finally lightbox stops to react sluggish as well. It was on 2 for whatever reason:confused:
