ZTool taking forever to load!
Hey guys,
I´m working on a model on my computer at my work, everything normal and smooth, when I bring the same model(ztool) and try to open in my computer at home it takes forever to load the model and when it does, it gets very slow!!
I have no idea what it might be, since the computer I use at home is a lot better then the one I use at my work.
Thanks in advance
P.S. This model have many different subtools, I think it must be one of this subtools is making it slow.
nobody??
Sounds like the subtool may be too big. I would try a couple of things. Save tool out as a tool, not a project. If that does not help then you may need to decimate it. There are methods to that. I am a bit rusty, I would look up help on doing that. I believe you decimate then remesh. But I do not remember.
Ultimately you laptop or pc at home may not be able to handle the poly count of your model.
