ztl ? in ver 1.55b
I have found the import tool button but can not find a batch convert of obj to ztl. Does 1.55b have a buttom to batch the obj to ztl?
TIA
when you import your Obj object , just go to the tools palette and save as … as usually and you will have you Ztl file… :slight_smile:
There is no batch importation but a zscript could be written to do that for you. How many objects are you talking about? And is there any special reason for your need for a batch import?
Fouad B. thanks for your help
TVeyes
not all for the world building project are obj’s some or 3ds and opj and some dxf - between them about 1,000 objects.
I think about 250-300 are obj’s
Thinking of making Zbrush the hub of the workflow (not to mention the ztl file sizes compared to the others) then transport out if needed from Zbrush
Thanks for your reply
Oh, space… sorry for my bad answer I not understand well your question.
you talking about automated workflow, as said below actually no, but maybe Z2 with the new system plug-in will offer that possibility or let the way open to the developper.
There is a thread somewhere I just read…I believe maybe thru the quicklinks section…where someone wrote a batch covert script…I think it was Cameyo but I am not positive. You could try a search with user name first I suppose.
I am sure Frenchy would remember who it was tho.
Yes…i have done a batch to import obj (and few other things)…but i don’t remember the thread…
Search ZForum with my member ID.
cameyo
cameyo
thank you did search and posted to the thread.
I do not know how to use the program
here is a babble fish translation of the help file
In the first page (Files) it indicates which are the rows to elaborate. If you must some only cancel one of that you have already added enough to select it and to press Canc. In the second page (Structure) indicates: Head - what must write in head to the rows a single time Body - what must write for every rows selected Tail - what must write in tail to the rows a single time In the body is important to know that: % mean the single one path of the rows select $ mean the single name to you of the rows select to you (without east.) ! it means the single extension of the rows selects to you (comprised the point) In the third page (Output) it indicates: Up as it must be called the rows scr the push-button “Creates rows” executes you the creation of the rows that still does not come saved but visualized in the memo it centers them the push-button “Loaded” concurs you to load rows already created (not servants nearly to a c…) The push-button “You replace” concurs you to make tries and you replace on memo the push-button “Saves” up saves your rows with the indicated name. Example: To create DXF from DWG (Autocad) To select all the dwg in issue In the body to write: _ OPEN (Open instruction of autocad) % $ (path and name rows) _ DXFOUT (Dxfout instruction of autocad) [ enter ] (confirmation of the name rows) _ v (option version) R12 (number version) [ enter ] (confirmation of decimates them) The two enter final why the dxfout it wants two confirmations, one for the name rows, one for decimate them (default 6). If you want to change it in place of the second enter us you write the wished number. Saved the rows with extension scr it drags it within autocad opened on an empty design with the manager of the resources. FAMOUS: Set FILEDIA = 0 in Autocad in order to see what must put in the SCR
