When I press Bind Mesh and try to pose the character, only the zspheres skeleton moves. What am I doing wrong?
Hello @ejrm93
If your target mesh is masked, no movement of the points is possible.
Otherwise the binding of your rig may have been broken for some reason. Try un-binding, then re-selecting the mesh from Rigging> Select Mesh and re-binding.
If that does not correct your issue please contact ZBrush support and provide the file for examination.
Thank you!
