ZSpheres locked to an axis: will only move or rotate along one axis.
I’m learning zspheres and I’m trying to make a male and female base. After making the female, I saved a copy of the file and began tweaking it to create a male. Somewhere along the line after making the new file, several of the spheres that make the torso became locked and only moves in one direction, forward and backwards. This is not present in my previous file, and I’ve tried restarting the program. Does anyone know what is causing this?
Go into your “Transform” menu and scroll down to “Modifiers”. Open up that “Modifiers” section and make sure “XYZ” is selected. It sounds like yours might be set to a single axis.
