any reason why a bvh export option, for zspheres, would not be looked at ?
is this possible with zbscript ?
I’ve not looked closely but I don’t see why this wouldn’t be possible, within the limited capabilities of zspheres.
Yeah I’ve considered this before and it should be possible , like marcus said within limited capacity of ZSpheres and ZScript though, but I don’t see why it wouldn’t be possible. Even bvh import would be possible with ZScript, i.e. create ZSphere rig through zscript based on joint hierarchy defined in bvh and then interpolate angles etc for various frames based on rest of bvh channel data per frame.
I was working on ZAnimator lately but I don’t have time for it, or this bvh idea, because of uni. Though I should note that my honours project is in the field of animation and involves lots of mocap / bvh file handling so i understand the format quite well, but my project however is to do with new advanced animation techniques/maths research.
Cheers
Darukin
Could you tell me where you got your resources for BVH fomat.
I am working with the format as well.
I managed to get some code from a guy at a convention that did a lot of it for a mocap studio.
I am just looking for how its dealt with.
Thanks.
It would be great to import BHV files…translate it somehow to the zspheres and timeline. I would try to make my own script if someone could give me some tips i would really apreciate it.
Hi StephenCook, do you mean how do I parse bvh_files and / or export them?
So far I do this in C++ and OpenGL, you must research the structure/hierarchy of a bvh file to understand it though so you can parse it accordingly. It’s alot of work that I can’t explain in one post, however if I come across any particular reference I will post it here and I can try get some pseudo code soon if you want as far as how I parse it.
I’m very busy right now with this research project and dissertation though, but once I free up a little I will look into translating this for ZScript so that we can have a bvh_format parser for ZSpheres, which i think should be possible =)
@dargelos: unfortunately there’s no ZScript support for the active Zbrush timeline. However I have created my own timeline system in ZAnimator and were I to create bvh support I would integrate it with my own timeline for ZAnimator. I think it’s a really good idae you have though so I may look into this after my dissertation’s complete.
I better wait for your new version of Zanimator system… I hope the guys in pixologic gave more importance to the rigging animation part because i think its actually very good and the most of the people don’t use it much. I don’t know how hard it would be to paint the weights with masks as you suggested a long ago but it would be so cool.
My question is in regards to the formation of the BVH file from the refrence nodes.
I have looked at the BVH file format in detail and have a lot of resources that talk about Matrix calculations. The funny thing is that no one has described the process in a way that I can understand. For example they give the formula but no way to see it working. I mean I would like to at least see how the values of a node are plugged into the formula then the result is stored.
I know some of this is very advanced stuff however without seeing it in action its difficult to understand how the formula works.
What I am working on with the BVH format is not directly related to ZB here. I just need to understand how to apply the formula to a single node.
I understand the file format but what I need is to understand how the first few values are generated. The steps involved would be helpful.
Thanks for any assistance you may give.
I think to be able to I/O a standardized “bones” animation/rig (.bvh),
combined with the new .MDD I/O capability
will have powerful implications.
why not put I/O “hooks” on all the timeline tracks,
so that GoZ(t) can be achieved.
Also, would adding constraints to zspheres be just a few lines of code :
like:
if(thisZsphere.AngleTo(next_sphere) > 30) {
print “the rigs says don’t do that”;
//TODO : constrain the zsphere.
hey, just kidding,
it’s probably a lot more complicated than that.
http://www.character-studio.net/bvh_file_specification.htm
I really think it’s time PixolLogic looked into
http://www.swig.org/
zbscript is… an ugly button pressing macro thingy.
;p
#!/usr/bin/perl -w
use strict;
=head2 REFERENCES
http://www.pixologic.com/docs/index.php/ZScript_Command_Reference
=cut
TODO : READ FROM FILE
my @bvh=undef;
sub bvh { # string[]
my $data = <<END_BVH;
HIERARCHY
ROOT Hips
MOTION
Frames: 222
Frame Time: 0.033333
0.00 39.88 -0.01 -1.79 -18.43 -1.74 5.02 -0.34 0.03 6.61 42.19 7.67 -3.87 -7.61 1.40 3.65 15.11 -0.95 2.33 11.06 -15.20 -7.25 -10.08 1.61 4.89 18.33 11.12 -17.68 0.00 0.60 40.98 9.99 22.36 0.00 -30.82 11.92 0.00 0.00 0.00 10.97 0.00 12.96 -37.45 -2.92 9.36 -180.00 -80.59 157.44 0.00 0.00 0.00 -35.59 52.18 0.00 11.29 -39.90 61.74
0.11 39.87 -0.01 -2.31 -17.29 -3.05 3.19 -4.22 0.24 7.38 40.49 -1.01 -3.87 -7.94 1.38 3.46 13.75 -0.82 2.47 11.44 -14.02 -7.25 -10.10 1.61 5.82 17.00 12.55 -17.36 0.00 2.00 42.28 10.77 34.97 -0.85 -22.68 14.90 0.00 0.00 0.00 10.01 0.00 11.77 -40.78 -3.61 6.09 -178.56 -87.20 158.39 0.00 0.00 0.00 -36.14 51.71 0.00 10.04 -38.83 61.13
0.22 39.88 0.02 -2.83 -16.47 -4.56 1.98 -6.94 0.24 6.27 37.48 -5.85 -3.87 -7.23 1.43 3.26 12.76 -0.72 2.52 11.87 -12.69 -7.25 -10.11 1.60 6.78 15.96 14.27 -16.96 0.00 3.28 44.28 12.02 51.41 -0.44 -17.87 20.64 0.00 0.00 0.00 9.19 0.00 10.84 -44.55 -3.26 2.86 -0.03 -85.90 -23.56 0.00 0.00 0.00 -36.74 50.88 0.00 9.12 -37.86 60.76
0.32 39.92 0.19 -3.51 -17.17 -7.03 1.79 -6.29 0.20 2.67 31.81 -3.40 -3.86 -5.65 1.54 2.98 13.46 -0.69 2.23 12.43 -10.34 -7.26 -10.29 1.58 7.48 16.60 16.65 -16.32 0.00 4.70 47.12 13.31 65.41 0.63 -16.14 26.83 0.00 0.00 0.00 8.37 0.00 9.94 -48.32 -2.20 -0.50 0.41 -78.48 -23.57 0.00 0.00 0.00 -37.20 49.91 0.00 8.35 -37.07 60.23
END_BVH
/, $data;
return $data;
our $bVh=bvh; #sting;
our $depth=0; # int
our %root; # struct
our $zscript="// created by parsing bvh file
"; # string
start
my @bVh=split /
/,bvh; # []
buffer
my %previousNode;
for each line in the bvh file :
for my $i (0…scalar @bVh -1){
# if $node{channelCount} != scalar @split;
} else {
$zscript .= " [ZSphereAdd,$node{offset}{x}, $node{offset}{y},$node{offset}{z},$node{radius}]
print $zscript;
