Hi new to the forum. I’m learning all the tools in Zbursh still and using version 4R8. I’m building a tree. The trunk I started off with a cylinder mesh. I wanted to make a branch with more control on the shape. So I built that mesh with Z-spheres. Now I want to delete one section of the mesh (off zsphere) where the branch will but next to the trunk. I choose Make Adaptive skin on the zsphere. However now I can’t find in the menu where to delete the mesh. Normally I would go to: Geometry-Modify Topology-Del Hidden. However when I have the zsphere mesh selected I don’t see the Modify Topology in the menu. Is there an step I missed, so I can choose to delete the hidden geometry?
You can’t delete hidden on a Zsphere Preview mesh. You need to make sure you’ve made an adaptive skin and you have that mesh selected.
That makes sense. After I got the shape I wanted in the preview mode, I used “Make Poly Mesh”, and then I was able to delete the hidden geometry. Thanks!
