ZSphere posing question?
Ok I’ve put Zspheres throughout the model but when i go to pose the head the legs move with it i don’t know what to do?
Hello @Solidegg
If your mesh is fully rigged with a zsphere skeleton, only the parts of the model that fall under the the influence of the Zspheres you are moving should move. It may be that you dont have enough Zspheres assigned to other parts of the mesh to keep them from being moved. We would need to see pictures to offer critique.
If your mesh is only partially rigged, or you are posing via transpose, then you need to mask or hide sections of the mesh you don’t wish to be affected by the posing operation.
