howdy,
so there was a post on this forum that said that while you are drawing out a zsphere, if you press CTRL, you will cycle from MOVE to SCALE to ROTATE.
i have NOT found that to be the case. BUT…
if you HOLD DOWN CTRL while continuing to draw, you will no longer be scaling the size of your zsphere - instead, the zsphere will start to slowly shoot OUTWARD in a straight line. and then, after having held down the CTRL key, if you release it, you will be able to move your zsphere around as if in move mode (your pen cannot have left the tablet during any of this however).
while pen is still on tablet, if you HOLD DOWN CTRL AGAIN, now you will be able to scale the zsphere again and if you release CTRL, you will be back in move mode.
WEIRDER:
if you draw out a zsphere and then just TAP CTRL, you will not be in move mode but instead you will start drawing out a NOODLE with new zspheres forming along as you draw and you will end up having drawn a chain of zspheres.
at no point and with no experimentation with the control key was i able to get ROTATE.
is this behavior universal for everyone?
is this documented anywhere?
jin
