I have been trying to make a simple script that:
Goes to the loaded AppLink Front View
Groups visible as single polygroup
Uses Group front at a 87 degree angle to create a new polygroup
When I record it as a macro I get the following:
//ZBRUSH MACRO - Recorded in ZBrush version 2019
[IButton,???,“Press to run this macro. Macros can be aborted by pressing the ëescí key.”,
[IShowActions,0]
[IConfig,2019]
[IFreeze,
[TransformSet,1176.85852,586.10614,-309.43127,174.77311,174.77311,174.77311,16.67798,-153.64848,164.53727]
[IPress,Tool:Polygroups:GroupVisible]
[ISet,Tool:Polygroups:Angle,87]
[IPress,Tool:Polygroups:Group Front]
This works fully as a script, but if I wanted to load a different saved view, it uses the TransformSet coordinates. So I took out the Transformset command and replaced it with:
[IPress,Document:ZAppLink Properties:Front:Front]
This leaves me with the following macro:
[IShowActions,0]
[IConfig,2019]
[IFreeze,
However the moment Zbrush hits the [IPress,Document:ZAppLink Properties:Front:Front] bit, it will not advance any further down the macro, so it goes to the loaded/saved front view, but does not do anything else (it does not create polygroups).
Lastly if I delete the [IPress,Document:ZAppLink Properties:Front:Front] bit, the the macro will run just fine, but I obviously want it to first revert to the saved view.
I have tried searching documentation, google and the forums, but I can’t find any explanation of how to troubleshoot a script, or any similar error.
Hopefully it is something simple/stupid and someone who has more experience can point out what I am doing wrong.
Many thanks in advance,
Tobbe
