I saved a script after a productive sculpting session but I can’t get it to play back. When I load it the text shows up rather than the button. I see text trying to define a button, but I don’t have the option to actually run the script.
Any idea what could be causing this problem?
After I discovered this problem I tried restarting and recording another script. I was able to get the second one to play back but not the first.
I tried modifying the scrpt. I noticed that the define button command had an opening square bracket and wondered if a missing closing square bracket could be the problem. So I added it and loaded it again. I then saw a syntax error message. So I took the closing bracket away and scanned the text in zbrush looking for another error message. I didn’t find one.
ZBrush will not show the entire document, but I do see the end of file when I load it in notepad.
Also, I tried to attach an image to the image plane x at first for reference, but had to give it up when I couldn’t figure out why the image plane seemed transparent. I’d like to delete these from the script and play back just the sculpting session if that’s possible.
During the sculpting session I created a zsphere model then pressed make adaptive skin, switched to the skinned version, subdivided and continued from there. I mention this because I’ve noticed trouble playing back scripts that switch objects in the past.
I’d love to hear any suggestions on what the problem might be.
