Hello,
I’m trying to create render passes export macro. I really need it to process and showcase a lot of models, so creating automatization is essential for this process.
So far everything is going fine until I needed to automate saving Mask, Depth, and BPR render to seperate psd files. When I try to record pressing and saving either the BPR, Mask or Depth it seems not possible. What I get is
ZScript Note: Interface item could not be found.
ERROR: Render:BPRRenderPass:Com
IN: [IPress,Render:BPRRenderPass:Com]
I tried doing it several different ways but the problem stays the same. This is what the script looks like when I record saving single Render Pass.
What I need is essentially export these three passes to either one or seperate files, so later on Photoshop Actions can pick it up and process it further.
//ZBRUSH MACRO - Recorded in ZBrush version 2021
[IButton,???,“Press to run this macro. Macros can be aborted by pressing the ëescí key.”,
[IShowActions,0]
[IConfig,2021]
[FileNameSetNext,“C:_Prep_Portfolio\BPR_Composite.psd”][IPress,Render:BPR RenderPass:Com]
Thanks!
