im getting this at the startup of my zbrush2019(doesnt stop me from using it, but annoying to always get this every time i start
Can you post an image of the contents of the ZBrush 2019/ZStartup/ZPlugs64 folder? In order to see what might be causing the error I need to check that files have been installed correctly.
thanks for giving me the directory. i deleted the fbx import from 2018 and it fixed it(i moved zstartup over from my z2018 to get all my stuff up to speed in 2019
thank you so much
You should not copy plugins from ZBrush 2018 to ZBrush 2019. There will be conflicts that cause problems that can be difficult to track down.
