When I try getting a Zremesher Guide to circle a mesh (drag + shift) it never goes where I want it to. Is it because it follows the topology ? Just need to draw in a straight line.
I think it follows the form of the mesh. If the shape you’re trying to draw it around is too complicated (more complicated than a tube-like shape), it may not understand what you want it to do.
Just to clarify, the procedure for doing this is to start drawing a line with the Zremesher guide THEN hold down shift to get it to wrap.
Keep in mind that Zremesher guides are meant to be quick suggestions to ZRemesher, not a blueprint. The more guide lines you draw, the less effective they become.
