Hello everybody, is there a way to more signify the priority of a zremesher guideline when zremeshing ? I have enough polygons set to the more detailed area, it tries to somewhat follow the line, but is there a way to make sure the mouth and eye area are absolutely remeshed like in picture ?
The Curves Strength slider in the Zremesher menu determines how much influence the Zremesher guide curves are given. The more influence the guide curves are given, the fewer should be used. There is no way to ensure 100% absolute adherence to specific polyflow unless you manually retopologize.
Is that a Dynamesh object? Maybe converting out of there would help you. (PS: the whole interface and PolyF enabled are useful to us and perhaps you as well)
