Ok, I’m starting to feel pretty comfortable in ZBrush 3.1 now, but some tools seem to behave oddly at times and I’m wondering if anyone can help me figure out more about projection, especially the Zproject brush as used to project contours from one subtool to another.
In the past, I know I’ve used zproject to both raise one subtool’s surface to another subtool’s surface above it and also used it to press a subtool’s surface down upon another subtool’s surface below it, but now it only seems to work in the raise direction. There have also been times in the past when I found that it would not work at all.
I know that this must be another case of complex software settings, some button left unpressed has put the tool into a mode where what I’m trying to do with it just won’t work, and I don’t know where to look. I want to fix my problem, but I also want an overall understanding of this so I can troubleshoot it for myself. Where would you suggest I look?
What I’m trying to do with the zproject brush, is morph an existing head model so that it conforms to another existing head model. Seems pretty straightforward, but because of some features like the close spacing of the lines at the corner of the mouth, the nostrils and ears overlapping the sides of the head it won’t just project automatically.
Also, has anyone else noticed that when you have the zproject brush and switch to transpose move, to move a whole subtool, that it behaves very oddly?
