Is there any way to make ZBrush zoom under the cursor? When I us/stroke the Zoom button, the whole mesh will move off to the side out of view. The more I zoom the more I have to use the Move button to slide the screen up or down to get to my desired location. Some times I have to swipe 6 or 7 times. This is a pain - help!
Hi @LD1
Turn on “Transform > Local”. This tells ZBrush to scale and rotate around the last edited point rather than the model’s center. If you are using a mouse, you can bind the scroll wheel to the “In” and “Out” buttons in the “Document” menu. The mouse wheel will zoom in to the cursor position.
That just what I needed to know. Thank you!
