Znodeler-- temporary polygroup
While using Zmodeler----
Is there a way to “clear” the temporary polygroup after it is drawn using ALT ? (white poly)
If you ALT click the poly again it will change it to a new polygroup (not white)
Is there a way to deselect it and return it to it’s original polygroup color ? Let’s say you accidentally selected a poly and want to return it to it’s original polymesh color. Yes, you can hit undo and go back to where you selected by accident, but, there must be another way (??)
(Yes, I can go through and hide polygroups I don’t want to effect and hit ctrl-w and make a new polygroup. However, when there are 20 polgroups already to the model this becomes quite time consuming. So, I’d prefer if that is a bit less taxing.
Is there a method ?
Thank you
SOLUTION:–> While in Zmodeler- Click on a colored poly that you want to ‘copy the color from’> while holding the click on that poly press SHIFT> release click and release shift > Now click on the polys you want to ‘paste’ the chosen color to.
Answered by Pixologic Kingsley via Joseph Drust-- Thanks guys !
