ZModeller Polygon Menu
This is a bit of a strange issue I’m having with zmoddeler on 4r7 and the polygon command menu that’s started recently after it working fine for months. When editing polys and right clicking or pressing the space bar to selct a command the command window appears at the top of the screen with the top line of commands hidden no matter where I click. The sub menus for any command I select doesn’t bring the sub command menu up until I press a random button on the keyboard. Then it comes up as usual. This doesn’t happen when using the command and sub menus when editing edges or points. I only have this issue with the command menus and sub menus for the polys. Any help with this will be much appreciated. Driving me nuts lol. I’ve also tried uninstalling and reinstalling 4r7. Thanks in advance for any help
P.S. Ive uploaded a screenshot
Appears you need P3(point release) :wink: Could help.
Its worth a try, thanks. Really curious why it started out of the blue and only affecting the poly command window though
