ZModeler Wishlist
This is my very first Zmodeler project, a Camaro 68. Although I primarily use Maya for my modeling work, I wanted this time to explore ZModeler.
The car model is far from perfect, and I really couldn’t enhance it further as I badly missed basic tools that would have made my work more precise and easier, such as:
  1. The ability to manually select a group of points and edges to move/manipulate them. I did use masking and ZM points/edges move tool as much as I can, but there is a limitation and inadequate control in such tools.
  2. Edge extrusion (extending edges like Maya for example). I overcome this missing tool by adding an edge loop to the end of a poly for example and then move the added edge to where I want, but it would be nice to simply have an edge extrusion that extends/make another poly of a plane geo for example.
  3. Edge cut tool (adding edges manually/connecting edges between points manually). This is by far the most missed tool and I did struggle a lot in modeling the car absent such a tool and ended up with lots of unneeded polys because I couldn’t manually change the topo of many of the model parts.
So, those are basically my ZModeler wishlist that I truly hope they will be added in future releases.
I understand that ZBrush is essentially a sculpting software that recently has added more controlled hard surface modeling tools like ZModeler, just like Maya for example is essentially a modeling software that in the past years began introducing sculpting tools. The idea basically is to have a full 3D sculpting/modeling package rather than jumping from software to another, which is a great idea. This becomes even more practical in ZB where we can create base hard surface models within the software to expand them further with its powerful sculpting tools.
Great start!
and I wish zbrush on the upcoming release take into account the points you mention edge extend would be a time saver also as edge cut tool.
I would like to see in ZModeler, a tool for aligning the surfaces of all polygons to the normal. It often happens that when editing points, the normal of these points is shifted.
Editing of vertices, edges, polygons, I would like to do, by simply holding them with a selection with a brush, using LMB, with an automatic call to Gizmo.
