Zmodeler window display problem
hi, i can’t see the entire windows when i open the “menu” (delete, inset, mask,…) of my zmodeler on a polygon
GGGGG67
Hi @Pianta_Grassa. Sorry you’re having a problem here.
The ZModeler Menu should pop up over whatever element you currently have highlighted when you press space with ZModeler active.
  1. May I ask what screen resolution you’re currently running Zbrush at? Bear in mind the recommended specs are 1920 x 1080 or greater.
  2. Is this behavior that happens all the time, or only sometimes? Does it happen even if you close the program then restart it?
if I restart the program or the PC the problem persists, how i can change the screen resolution for zbrush?
You’re running Zbrush at whatever resolution your screen is set at. You would have to go into your OS display settings to check . In Windows you can right click on the the desktop and go to “Display Settings”, and your screen rez should be listed there.
problem fixed thanks very much
Excellent!
Happy Zbrushing!
